e3-10 error- contact spring
  • ansuman
    • Oct 2008
    • 14
    Dear John(Peanut)
    I didn't find the contacts spring(ref-no 1557) that is to be attached with the Fly-Wheal in India .Pls give us an optional ans to this problem.We have also tried with Aluminium and Copper wire,but the results didn't show any positive effects.Neithe the cintacts spring nor the contact plate is available in India so pls give us an optional solution.
    Thanking u
    Ansuman
    India
  • The-Peanut
    • Aug 2006
    • 192
    Originally posted by ansuman
    Dear John(Peanut)
    Thanking u
    Ansuman
    India
    since u r unable to get hold of the parts, i would go along with what Mad Coachman said. Remove the flywheel and wrap a large paper clip around the flywheel shaft then attach the other end of the paper clip behind the metal frame. re attach the flywheel and u should be ok.
    John
    • ansuman
      • Oct 2008
      • 14
      e3-10 error
      Dear
      John(peanut)
      Sir
      I am unable to understand where to connect the other and of the paper behind the metal .Will u be pls kind enough to show the diagram in graphics.Pls help to solve this error.
      Thanking u.
      Ansuman
      • The-Peanut
        • Aug 2006
        • 192
        Dear
        John(peanut)
        Sir
        Thanking u.
        Ansuman
        On that T.B i sent u, Fig. 3 shows u how to wrap the wire around the drive shaft then tension the other end against the frame. Just use a large paper clip instead
        Hope that helps
        • Mad_Coachman
          • 99
          DAFT
          Hey John,
          I thought it was very good of you to post that bulletin for Ansuman.Quite frankly if he can't figure it out from that then maybe he's in the wrong line of work
