panasonic facsimile panafax
  • dj101
    What does it mean when the fax machine says error code 316 printer engine failure.?
  • imagertech
    • Apr 2005
    • 41
    Reanasonic facsimile panafax
    depends on the model
    • links
      • 9
      Panasonic ( Panafax UF-XXX ) Error Codes
      001 recording paper jam
      002 recording paper jam
      010 no recording paper
      014 print cartridge is not attached
      015 out of ink
      017 wrong paper size
      030 document misfeed
      031 document jammed or exceeds maximum length (2 meters)
      039 during dialing, STOP was pressed
      041 out of toner
      045 no toner cartridge
      060 a cover or door is open
      061 a cover or door is open
      063 jam access cover is open
      316 clean the ink station overflow tray and encoder strip on inkjet models
      400 during initial handshake, RX station did not respond; comm error
      403 no polling capability at remote side
      404 during initial handshake a comm error occurred
      405 during initial handshake a comm error occurred
      406 password mismatch
      407 no confirmation from the RX station for the previous page sent
      408 remote side confirmation of previous page is illegible
      409 remote side confirmation of previous page is illegible
      411 polling password does not match
      412 no data from the transmitting side
      414 polling password does not match
      415 polling transmission error
      416 received data has too many errors
      417 received data has too many errors
      418 received data has too many errors
      419 received data has too many errors
      420 machine enters RX mode but receives no command from TX side (not a fax calling)
      422 interface is not compatible
      427 interface is not compatible
      430 comm error occurred while receiving
      434 comm error occurred while receiving
      436 received data has too many errors
      456 memory overflow on confidential document or relay request
      490 received data has too many errors
