4" x 6" bypass paper size
  • rizwan143
    • May 2015
    • 42
    I have a Panasonic 8035 machine.
    How can i print on 4" x 6" paper size from bypass tray. when i print on it selecting "A5" from paper size for bypass. the paper mostly gets jammed. how can i put the custom size in bypass tray .
    • 23009
    Re: 4" x 6" bypass paper size
    A5 (148mm x 210mm) is the smallest acceptable paper size for this copier. 4" x 6", or Ofuku Hagaki, or Albert (101mm x 152mm) are too small to feed through this copier.
    It's never gonna work. =^..^=
      • 16401
      In other words, he should look at the paper specs for this copier?
        • 23009
        Like this: Panasonic DP-8035 Multifunction Printer-Scanner-Copier-Fax
        Google is your friend. =^..^=
