Panasonic DP4520
  • AverageTech
    • 18
    Panasonic DP4520
    Having a intermittant E01-22 problem( polygon motor synchronization problem). Already swapped out the CCD unit. The service manual says the LVPSis next, but if it is, wouldn't i have different error codes? I think it's the SPC board. None to try. Expensive guess. Anyone had this problem before. Thanks in advance.
  • copytechman
    • Nov 2008
    • 969
    This may sound stupid but what does a ccd (scanner) have to do with a laser unit polygon motor assy or the like? I would have gone to the laser unit 1st to look at... have u swapped the laser unit or the like?
    Regards.
    A.
    • AverageTech
      • 18
      My bad. I swapped out the LSU assemble not the CCD. Sorry for that. You are correct to point that out.
      • copytechman
        • Nov 2008
        • 969
        No worries, as for the lvps, well I guess thats a possibility, depends on how it supplies power to various options, can u hear the motor spin or try to operate it in an output check mode (if such a thing exists). I'd check all the fuses on the lvps if thats what the manual suggests @ least, do u have a spare to try?
        How is the motor controlled? By a main board or a sub motor control board or io board of some sort? Does the io board (if available) have fuses built on it like a lot of KonicaMinolta stuff does? And if so, are they good or not?
        Just stuff to think about.
        Regards!
        A.
        • scepter2112
          • May 2009
          • 72
          check door switches
          Check front door switches there is a laser safety switch. we had a lot of problems with it usually gives U1 code but can give laser code.
          • The Destroyer
            Road Warrior
            • May 2009
            • 17
            Hey, i had this problem and the customer had to turn the machine off and back on to use there copier but the code comes back. change out the charge corona unit.
            Jesse
