light coly on FP 7718
  • ginobuono
    • Jul 2025
    Hallo, i have changed drum, developer and cleaning blade, on a FP-7718, because i have dirty copy, after this i have a light copy and on foto esposure the copy it's invisible.
    i cleaned contact of drum, corona transfer wire and develop group contact but i do nothing.
    i think set the density of image but i have non know what do this, if someone can help me, the best it's if someone had the service manual.
    thanks
    ps sorry for my english
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • ginobuono
      i have a manual service e parts buy on freeservicemanual.net but there are nothing on service mode and i don't want buy an unhelpful thing.
      someone can post me the rilevant page for my question or give me helpful for it?
      thanks for your answer
      gino
      • ginobuono
        sorry i do wrong, because i mount developer for FP7728 on the FP7718, i think it is the problem, moanday i order the dev fo 7718 and retry.
        thanks
        • Techace
          • 35
          panasonic fp-7718
          hello gino,
          when you installed new drum you have to go to simulation(F Mode).
          To enter simulation (F Mode) press these three keys simultaneously. "User Preset", "Ledger / A3", "3".
          To Exit Simulation (F Mode) press two keys simultaneously. "User preset", "Clear/ Stop". if you not use this procedure, the machine will remain in the service mode . shutting power or unplugging the copier will not clear it.
          after installing new drum:
          go to F6 mode and press "6" "1" Drum background compensation. Enter "0" after installing new drum (Range is -9 to 38)]
          after installing new developer:
          go to F8 mode and press "0" "8" developer callibration. then press "Print", "0" "9" "Print". Machine will cycle for about 2 minutes. when it stops, record the reading. developer callibration is complete.
          for exposure setting [copy quality adjustment]:
          go to F6 mode and press "1" "1". standard is 62 for 120 volts machine. 224 for 220 volts machines. each increment is .2 to .4 volts. Range is -99 to +99.
          if this above all not works. then:
          Exposure adjustment:
          go to F6 mode and press "2" "8" and enter value with number keys. use "Reset" key for [-] values or possibly the dark and ligt keys are used; [+] for lighter, [-] for dark. press "ok" key then press "Print" press "Clear/ stop" twice.
          apply these and after let me know about copy condition.
          reply to me
          Raheel
          (Techace)
          • ginobuono
            thanks so mutch Raheel, i caliber the developer and adjust the the darkness and all it's ok
            thankyou so mutch
            gino
            • Techace
              • 35
              thankyou so mutch
              gino
              good gino,
              i am really happy. the pleasure is all mine.
