U-16
+ More Options
Posts
  • Peter Sim
    • Sep 2008
    • 445
    U-16
    Hai all ,
    Dp1520 show u-16.The developer unit connector already connect but still show U-16,could anybody know how to clear the u-16? Thanks in advance.
  • onetek
    • 318
    is the second connector between drum unit and dev unit also plugged in? Th.
    • The Destroyer
      Road Warrior
      • May 2009
      • 17
      DP-1520 i have about 3 of theses in the field
      check the to see if you screwed in the developer unit. before you screw it in open the left side door drum side then check if its screwed in other wise
      chech the wire harness and were it plugs in for bent pins.
      • Peter Sim
        • Sep 2008
        • 445
        Thanks for yours reply, i will check.
        • The Destroyer
          Road Warrior
          • May 2009
          • 17
          keep looking for the detection behid process unit might be bent
          Did you have thie error u16 before working on machine?
          i hav taken a lot of these apart to change developer
          i would dubble check your work and chech all the connectors to make there together right i see bent pins on connectors and gives a error
          dose the door close with u16
          • Peter Sim
            • Sep 2008
            • 445
            Thanks for your reply,i check all the connector with 8-pin connector and 4-pin connector on the developer unit are find.The u-16 still appear.
            • onetek
              • 318
              I would test the dev unit on another machine if you have one handy.also, try another tdc sensor (and make sure the connector is plugged in all the way in the sensor).and clear the memory with a shippment set..Th.
              • The Destroyer
                Road Warrior
                • May 2009
                • 17
                Hey have you gone to service mode and use out put test f-4
                Hey have you gone to service mode and use out put test f-4 to test developer sensor.
                • Peter Sim
                  • Sep 2008
                  • 445
                  Thank for your reply.Under f4 input check-008 >1.Developer is connect.
