pana dp 2010 abnormal noise
  • marra
    • Sep 2009
    • 4
  • gordie
    • May 2008
    • 83
    Hi The only noises i have had from a 1810 is the paper tray lift assembley.
    Regards Gordie
    sigpic
    • The-Peanut
      • Aug 2006
      • 192
      Hi George
      these range of machines have 1 engine box at the back that drives the fuser,drum,Dev unit & toner bottle rotation etc, they r prone for constantly braking teeth on the gears under any slight pressure, remove the box. turn the drive by hand and see if you can notice a slight skip on the gears, check for cracks on the gears also
      John
      • Wheedoggi
        Regards Gordie
        so mote it be
        • gordie
          • May 2008
          • 83
          Small world i used to work for agfa until 1987
          Regards Gordie PM
          sigpic
