panasonic DP-3510 e03-40
  • ggurke
    What do i do to fix this
  • suckis
    • Dec 2006
    • 165
    E3-40 - Copy Density Sensor output adjustment
    1. Sensor connector is disconnected.
    2. Sensor is defective.
    3. SPC PCB connector is disconnected.
    4. SPC PCB is defective.
    Hope that helps.
    ! RTFM !
    My site: http://www.e-club.gr/
    • alfpanasonic
      • Jan 2007
      • 73
      e-3-40
      clean the drum sensor
      • Clutch
        • Jun 2005
        • 15
        You can turn off F5-25 in a pinch if you need to wait on parts.
        Clutch
        • tseto
          • Jun 2007
          • 60
          black density error
          just to add that when the copier is allowed to operate under low toner (u13) condition, developer is depleted quickly , and when toner is replaced, the machine will overtone and results in a dirty machine. We have converted all high speed 35xx-60xx series copier back to using OEM toner. This drop the frequency of e3/40 calls to almost zero. If youb are using katun or densi toner , be sure to leave a spare bottle and change the function to " STOP" when toner is out.
          • suckis
            • Dec 2006
            • 165
            1. Clean inside the machine
            2. Change the developer if needed
            ! RTFM !
