DP-8035 no LAN response
  • suckis
    • Dec 2006
    • 165
    I have a DP-8035 and the customer said that suddenly they cannot print anything.
    I went to the customer' s place and I realized that the LAN' s LEDs were not lit.
    I tried with my laptop and a cross cable and I could not ping to the copier. I connected my laptop to the cable that was patched to the copier and I connected to the local network. That means that my laptop and the customer' s cable are both working. I all ram initializations and the problem still persists.
    Any ideas? Should I try changing the PC board or try something else before?
    Thanks in advance.
    ! RTFM !
    My site: http://www.e-club.gr/
  • mjunkaged
    • 386
    How to fix a panasonic mono mfp....
    Okay, so first, remove your company's sticker from the machine, then place it on a GOOD machine......but all kidding aside....
    Try a hard reset: I believe you hold the function key down while turning rear main power on, don't let go of function until you get the change in the display...from there I can't quite remember, but what I DO remember was it was the only way I could reset an error 'stuck ' in the machine.
    By the way, what's your firmware like? Up to date? VERY important on that model! And it has f.w. for the nic i believe. If I'm wrong an ACTIVE pan. tech. can smack me down........
    • mjunkaged
      • 386
      ALSO:
      Don't forget to check the network settings to see if they're still stored, if not you may have a flaky battery connection or near dead battery if you've lost settings/data.
      • Vista Tech
        • 116
        No LAN led's on the back of the machine = bad. I would reseat the net card and check the connections inside it. If the customer has been moving the machine around it could be a possibility that they damaged the connectors inside there and it needs a new card. If you have a spare card or machine laying around anywhere I would also swap out cards just to try and eliminate factors, just hope its that card and not a board.
        • suckis
          • Dec 2006
          • 165
          The machine' s firmware is the latest. The customer also has another DP-8035.
          So, I went to the customer today and swapped the PC boards. The problem solved and the "good" machine got the same problem after swapping.
          ! RTFM !
          • Vista Tech
            • 116
            Well it sucks that it was actually the board. I was just about to say to also check the line to the computer itself lol, that's happened to me once before.
            • mjunkaged
              • 386
              Which board?
              So....was it the nic or the sc? We're all dying to know ....at least I am!
              • suckis
                • Dec 2006
                • 165
                The faulty board was the "PC board, SC" as written in the manual. This PC board includes the NIC.
                ! RTFM !
                • Jetbase
                  Fuse?
                  Look for a surface mount fuse. I beleive it is possible to blow the fuse or board if some nark has swapped Lan for a fax line this usually happens in the Lan connections room. I know fax boards blow if a Lan is plugged into the fax.
