DPC-262 E05-13 error
  • clivo
    Hi All
    I have the error E05-13 on a panasonic DPC-262
    The machine is stuck in a startup loop for ages then the error
    Anyone got any ideas?
    Cheers
    Clive
  • jasono@marconet.com
    Try unpluging the hard drive and boot up! I think I had something similar to this cant remember exactly. Hope that helps.
    • TONERINMYNOSE
      • Aug 2010
      • 114
      ALL JOB CLEAR
      Try using all job clear in f9, then trouble shoot the code, f9 should stabilize the panel.
      • mojorolla
        The Wolf
        • 2639
        The code is a board communication error. There are two main boards in this model; SC and EC. CN61 on SC and CN501 on EC. You can also try holding down the function and clear keys and then boot up the machine directly into service mode. If successful, try firmware update in F9. I hate to say this, but it is most likely the SC board. If the unit has an PS chip, try removing it before anything else.
        • Logged-on
          • Sep 2010
          • 197
          I can't say I've seen this code, but one thing I have noticed is the connectors on the PM kit fusers don't seem to fit as snug as the original connectors. I have had issues right after performing a pm, everything from paper jams to service codes. I slightly tweak the pins for the connector, and all my problems go away.
