Panasonic FP7742 w/FA-A888 doc feeder
    • 23003
    The document feeder on this one Z-folds between the registration roller and the white belt.
    I've cleaned the sensors & rollers. The rollers have tread (& pickup fine). I just found out how to recalibrate the sensors, that's next.
    Mostly I suspect the white belt. It's not so white, and a little saggy. Any ideas?
  • Luther
    • May 2006
    • 682
    The belt is most likely slipping and causing the z-fold, also check the double feed roller located in the door it has a one way bearing that goes bad and causes all kind of feed issues on this machine,good luck
      • 23003
      Thanks.
      Thanks Luther. I doubt that this customer will pay the parts cost, but I wrote the estimate today.
        • 23003
        Thanks!
        Well, they took the parts, and it worked. Thanks, Luther!
        There was a heavy buildup on the aluminum rollers also. You know, this document feeder looks remarkably like the Sharp SF-A56, or the RADF on the Cougars
