panasonic dp-8045 e07-20
  • popo
    • Mar 2009
    • 30
    hi
    this code appear when i start this machine i found the probleme in the finisher i remove it and the machine work but the error code still appear how can i clear this code *service mode *
    can you help with the service manual of this machine my email * krafar@yahoo *
    thank you for your help
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • mojorolla
      The Wolf
      • 2630
      This code is for the swing assembly. Open the top finisher lid and you will see a black baffle with fingers right after the entrance. It attaches through the rear frame wall into a coupling and attaches to a solenoid. Sometimes the coupling comes loose from the end of the shaft.
      • popo
        • Mar 2009
        • 30
        thanks but what is the sav mode to clear the code in this machine
        • TONERINMYNOSE
          • Aug 2010
          • 114
          There is no clear, when the problem is rectified, the code will go away
          • mojorolla
            The Wolf
            • 2630
            TONERINMYNOSE is right. Once the problem is fixed, it will disappear. Like you said in your previous post, with the finisher unplugged, the code goes away. Take off the rear cover and look behind the board. the solenoid and coupling are right there.
            • popo
              • Mar 2009
              • 30
              thanks but what is the SAV mode of this machine
              • PanaTech
                • Dec 2008
                • 71
                function + original size (ledger) + 3
                u can also try turn off the mc from the back and turn it back u, it will do self check to move the tray up n down
