E 3-86 code on panasoic dp-c354 help pls
  • Lopakadee
    • 11
    [Error Code] E 3-86 code on panasoic dp-c354 help pls
    i have a e3-86 code on a dp-c354 i've done everthing the book has told me to and more.
    i cant figure out whats the problem pls help the panasonic b2b websight sucks
  • mkb
    • Sep 2010
    • 23
    E3-86 Color Registration Sensor (Left)
    Calibration Error
    1. Sensor Shutter Solenoid connector is disconnected.
    2. Sensor Shutter Open-Close is abnormal.
    3. Toner Registration Sensor (Left) connector is disconnected.
    4. Toner Registration Sensor (Left) is defective.
    5. EC PCB connector is disconnected.
    6. EC PCB is defective.
    • Lopakadee
      • 11
      thx but iv done all that and swapped all the parts out with new ones. thats what driving me crazy
      • TONERINMYNOSE
        • Aug 2010
        • 114
        change the transfer belt?
        • Lopakadee
          • 11
          i'v done that also it pissing me off
          • PanaTech
            • Dec 2008
            • 71
            have you put the belt on properly? one side of the belt has a reflective (chrome) tape for the machine to do the alignment.
            • Logged-on
              • Sep 2010
              • 197
              When I've gotten that code, all I have ever had to do was wipe the three sensors under the IT belt, and the one sensor above the belt on the rear side of the frame.
              And as mentioned, make sure the 2 reflective patches are on the rear side of the IT unit, and make sure they are being cleaned properly.
              • vedder
                • 131
                I think when I have had that problem, I remove the cover where the copies come out (above the toners) to the back of the machine, there is a little black plastic box, remove, wipe the sensor and re fit, hopefully that should help, the transfer belt comes unstuck slightly flicking toner up onto that sensor, I sometimes cut the little bit off if it isnt time to change the belt.
                Hope you get sorted.
                • mojorolla
                  The Wolf
                  • 2630
                  Check the EC board. There should be 4 LEDs illuminated on the board. If any one of the four is missing, you have a bad board. Is the solenoid over the sensors working properly (F4-488) ?
