Jamming under drum on 8035
  • otuvak
    • Aug 2010
    • 102
    Having this problem of jamming under the drum catching on drum paw on rear side frame! It also gave an E3-12 code. Replaced coronas, drum. Open to suggestions! Thanks for the help!
  • mojorolla
    The Wolf
    • 2627
    Check the erase lamp/grid under the sep/tranfer unit. The rear side clips fall out. It always seems to be the rear side. You can also check the solenoid that activates the OPC sep fingers, and the horizonal motion of the finger bracket. There is also a tiny little return spring on the bar that activates by the solenoid and moves the sep fingers; make sure it is still there.
    • Mad_Coachman
      • 99
      it could be that the High Voltage power supply is not giving proper voltage to the transfer/separation corona unit.
