Panasonic dp-8045 not adding toner
  • TONERINMYNOSE
    • Aug 2010
    • 114
    I have an 8045 that runs all the toner out of the dv unit, i tried fresh dv, tdc sensor and working dev unit out of a good machine, i have f6-21 set to around -44, i was gonna go toner hoper but i would think if that was the issue i would get an add toner message, this is not the case just runs till its out of toner and keeps spitting really light to blank copies. Im sure im missing something stupid help!!!!
  • The-Peanut
    • Aug 2006
    • 192
    after removing the old dev and toner and replacing it with new dev, did you do a F8-09 in service mode,
    how long does it last before you have problems, i take it the copies start going feint?
    • mkb
      • Sep 2010
      • 23
      What is f5-25 set to. Also set f6-21 higher to the postive number.
      • mojorolla
        The Wolf
        • 2632
        Are you using third party toner? This can cause density loss with big jobs. This is what I do:
        -Set developer gap to 1.00 mm. The book says 1.05mm, but that is for genuine OEM toner.
        -Manually add toner under General Settings and run the F1 page memory test page. Add toner until this pattern is nice and dense.
        -Once the pattern looks good, I then run F8-9.
        - Set F6-21 to -35. Set F6-62 to 0.
        -Depending on which machine you have, some will have an F6-64,65. If it does, I set them both to 5. Sometime during production, they decided to remove the sensor under the OPC and the ADF gearpack on the front.
        -I have never had to turn of Quantum on these machines. The older machines (4530,6030) always have Quantum turned off.
        -There is also the 3 slotted gear that feed toner form the hopper into the DV unit. I have seen this get bound up with toner.
        • Logged-on
          • Sep 2010
          • 197
          One thing I do before doing anything else is to replace the Charge wire. I don't know if the techs you work with are as seemingly baffled by the procedure to replace the charge wire as the ones who work with me, but if the wire hasn't been replaced in a wire it will put an excessive charge on the drum, causing the density readings to be erratic. I would guess 50% of my light copy issues get fixed by replacing the charge wire.
          • Rick Martinez
            • Sep 2009
            • 77
            i totally agree with Logged-on it makes a big difference when you replace the wires.
