F6-21
  • otuvak
    • Aug 2010
    • 102
    F6-21
    Just replaced developer on an DP-1820e. I noticed that F6-21 set up at -5. Is this normal for this machine? Dont see these too often? Thanks for reading!
  • mojorolla
    The Wolf
    • 2627
    Most Panasonic have the F6 factory settings on a sticker inside tray 2. F6-21 at -5 does seem low to me. Other Panasonics run in the -35 to -55 range for that parameter. How does the copy quality look?
    • onetek
      • 318
      I have a tb that says f6-21 should be between -18 and -30 for this copier. But if it is stable at -5 I would'nt worry.( run 30 black copies)
      Th.
