Panasonic DP3010
  • ereeze
    • Aug 2025
    [Error Code] Panasonic DP3010
    How does one replace a fuser web on a Panasonic DP3010 and what is the level of difficulty.
  • mojorolla
    The Wolf
    • 2627
    Once the fuser unit is removed, the web assembly is on the back of the fuser and held in by three screws. It is not hard to replace. However, this is something a technician usually replaces.
    • ereeze
      How do I get to the web fuser and what is the level of difficulty associated with the replacement.
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Just Manuals | The Internet's largest selection of manuals | Instant Downloads
        Paul@justmanuals.com
        • ereeze
          Thank you all and I will be checking the Manuals4you website.
          • PanaTech
            • Dec 2008
            • 71
            open the side door, remove the plastic cover at the back to release the plastic latch and 2 harness, then remove another cover on the left of the fuser unit if u look into the fuser unit, then remove 4 screws, one on each corner of the fuser unit, u can jiggle around to have the fuser unit come out or u can remove the latch pin on the right of the fuser unit if u r facing the fuser unit.
            • PanaTech
              • Dec 2008
              • 71
              make sure u have the latest fuser web, the older model is lack of fuser oil and it will get stuck n scratch the heat roller.
