Hi. First time post.
Jam only occurs when in duplex mode. Paper overshoots the ADU 1 sensor on the first pass leaving the fuser. It jams on the reentry hitting the ADU 1 flag actuator. This happens frequently. I did an F4 -314 to check ADU sensors, they are working correctly. Intermittent issue is what's throwing me off. Any tips will be helpful. Most of the jams are logged as J 81, a couple of jams were logged as J 18.
This problem occurs in all paper trays.
Thank you.
Thank you.
