DP4520 jams
  • copiman
    • Sep 2011
    • 861
    DP4520 jams
    I have a DP4520 that has a spring pop off a roller from time to time. I go out, put the spring back on, and all is well. It is item # 8309 in the attached doc. Left hand side of copier, below the fuser. Anyone had this issue? I did notice alot of paper curl on the 14" church bulletins, 2 sided. Maybe jam removal causing spring to come off? Any known issues on jamming in this area? Runs just fine while I am there.12-16-2011.pdf
  • onetek
    • 318
    Re: DP4520 jams
    Its the springs that keep pressure on the inverter roller. I have had to increase tention on some to prevent jamming.
    Th.
    • mojorolla
      The Wolf
      • 2627
      Re: DP4520 jams
      As onetek has suggested, increase the tension. I will take a few coils of the spring and attached to the anchor point. Usually fixes it right up.
      • doug94550
        • Dec 2011
        • 138
        Re: DP4520 jams
        Personally, I have found the spring tension in this area to be critical.
        When mine start to wear out, I don't try to McGuyver them, I just replace them as a pair.
        They are a cheap part and it costs a lot more to keep sending me back.
        Also, while you are in the area, take a look at the inverter sensor actuator.
        Usually it has a spring attached but it falls off a lot.
        I don't put the spring back on, instead I glue a medium size e-ring to the actuator where
        the spring usually attaches. The weight of the e-ring allows the actuator to return smoothly every time.
        Doug
        • copiman
          • Sep 2011
          • 861
          Re: DP4520 jams
          Thanks everyone. I will try to adjust spring or replace if needed. Will look at actuator as well. Again thank you.
