3030 oil
  • Billy Bob
    USMC
    • May 2011
    • 51
    3030 oil
    any one come up with cure for leaking webs ? had both oem & generic
  • copiman
    • Sep 2011
    • 861
    Re: 3030 oil
    Sorry Billy Bob, I have not seen any leaking webs. Where do you get your webs?
    • Billy Bob
      USMC
      • May 2011
      • 51
      Re: 3030 oil
      pana / katun
      • mojorolla
        The Wolf
        • 2627
        Re: 3030 oil
        OEM or third party, they all will leak. I knock down the fuser temp by 5 to 8 points and its seems to help. That being said, some still leak from time to time. I have also noticed some new web are more oily or more dry then others; no uniformity. This is exactly why I save the fuser for last on a PM. That oil on your hands and then it gets on your tools..ugh!
        • onetek
          • 318
          Re: 3030 oil
          Getting down the temp helps a bit but sometimes i have some leaking bad enough to get to the drum.....Thats with pana webs.Even though ther's too much oil, heat rollers dont last.
          Th.
          • Billy Bob
            USMC
            • May 2011
            • 51
            Re: 3030 oil
            Thanks for the advice. It seems to happen more with machines that run a lot of big jobs all at once. Was thinking along those lines with the temp. I'll give that a shot and hopefully it will reduce the problem.
            Th.
            Thanks and yeah, have had a few of them leak that badly. It's such a pain to completely clean out every square inch of the drum and dev units and takes hours. Ugh. And I agree, the heat rollers never last as long as they're supposed to.
