Shipment Reset?
  • copiman
    • Sep 2011
    • 861
    Shipment Reset?
    What exactly does Shipment Reset do? Does it do anything to the developer or drum settings, or any thing else?
  • mojorolla
    The Wolf
    • 2627
    Re: Shipment Reset?
    It will reset all settings back to factory default. It will prompt you to clear the counters but I do not recommend this as it can mess up CQ because it thinks all components are brand new.
    • Sama
      • May 2010
      • 18
      Re: Shipment Reset?
      Caution:
      The factory default parameters are preset (country dependent) for optimum performance, and in compliance with the local telecommunication regulations/standards, and do not need to be changed. Changing some of these parameters may cause the unit to be no longer compliant, or become inoperable.
      • copiman
        • Sep 2011
        • 861
        Re: Shipment Reset?
        Thanks for the response. I saw someone do this and I thought that it would loose the settings for the F8's on the drum and dev. Feel better now.
