Panasonic DP3030 E03-40!!!!!
  • O sentinela
    • 20
    [Error Code] Panasonic DP3030 E03-40!!!!!
    hello guys. I have a Panasonic DP3030 put you a ruler and a drum cleaning and when I ran the f8-14 gave me a code E03-40. And the copies come out with background ..... I need help
  • O sentinela
    • 20
    Re: Panasonic DP3030 E03-40!!!!!
    hello guys. I have a Panasonic DP3030 put you a drum and a cleaning blade and when I run the f8-14 gave me a code E03-40. And the copies come out with background ..... I need help
    • mojorolla
      The Wolf
      • 2609
      Check the 2 sensors under the silver baffle on the right door, near the transfer roller. They are moved up and down by a solenoid. If the silver baffle is not installed right, it can bind the rear and keep the sensors from moving smoothly.
      • O sentinela
        • 20
        [ATTACH=CONFIG]15225[/ATTACH]
        Thanks man i really aprecciate your work and did work....i clean the sensor and the problem it's solve thanks again....
