All trays jamming panasonic 8060
  • vedder
    • 131
    [Jamming] All trays jamming panasonic 8060
    Hi everyone, after a bit of advice if anyone can help, I have a 8060, about 450K on meter, was called out for jamming from tray 1, other trays working (apparantly) when I arrived, I removed tray 1 paper feed section, it had 3 well worn feed tyres, smugly I replaced all three tyres, clean the unit up, rebuilt and ready to walk away, but no, instant jam, so I went through the usual stuff, strip, clean, rebuild etc etc, no change, put tray 2 feed station in, worked fine, so I decieded to get tray 1 and 2 working with the other paper feeds, and re book for parts and fix paper feed 1. When I rebuilt it all back up and tested, I couldn`t get a copy out of either tray 1, 2 or 3??
    I had all the back off, ran it with the waste bottle out, everything turns, drive motor etc, but still jams, it does though make a bit of a whine/squeak from the back area, quite hard to pinpoint, the paper is not getting out of the cassettes, it doesn`t even look as if its getting picked up, its showing j01, j02 etc.
    Another strange thing, just before I left the only way I could get to clear the jam code was by switching on and off, no paper anywhere, but that was the only way??
    Anyhoo, just thought I would put it out there, ALL help/ideas appreciated.
  • nmfaxman
    • 1702
    Re: All trays jamming panasonic 8060
    No offence, but you had to have caused it.
    Pinched wire, two connectors swapped, one connector not plugged in or not plugged in tight.
    I recommend a second set of eyes. Bet him lunch that he can't figure it out. It would be cheaper than spending hours fighting yourself and there is nothing wrong with a little ribbing.
    It happens to the best of us.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • mojorolla
        The Wolf
        • 2639
        Wow....a couple of scenarios....
        1. The trays are not lifting. A J01-02 indicates the paper never left the drawer. There is a flag and 2 gears on the back of each drawer. The motor turns on when the flag goes into the 3 sensors in the rear frame. I have seen these sensor packs get knocked out as well
        2. You have a bad SC board. You can go into F4 and test all the motors and sensors in the paper drawer and feed area. There is also a known issue with a wire that rubs the paper feed clutch. It usually give E5-01 in the error log but can cause any number of weird symptoms.
        3. You have one or more of the paper feed harnesses upside down. I only saw this once but it booted fine but jammed immediately.
        4. What nmfaxman said.
        • ESTANISLAOWENENTON
          place only 10 sheets in each drawer and try
          • vedder
            • 131
            just a heads up to the fault, I went back the next day with a full drive unit from a doner machine and fixed the fault straight away, my guess is that one of the clutches on the drive had gone, or possibly the motor, it was making a "funny noise" before I swapped it out.
            Anyway, thaks for the responses.
            • copiman
              • Sep 2011
              • 861
              Thanks Vedder, for the follow up. Follow up is a great service to everyone. Again thank you.
              • vedder
                • 131
                No probs, I agree it is always good to hear how the issue was resolved so it could make our lives a lot less stressful in the future, god knows I need a little bit of help everynow and then when you get weird and wonderful faults.
                Take it easy.
