Dp C354 Touch Panel Won't Calibrate
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    Hello everyone,
    The touch panel on this C354 has been acting up over the last few years. Randomly the touch panel will be off center an inch or so and the customer complains about it not working. I've been able to calibrate it every time it's done it in the past and it would work and would be fine for a few months. Now the panel is about two inches off to the right and this time when I tried to calibrate the panel, it won't work. I can enter the calibration mode but after I press the first + it won't accept it when I press the second one. I tried reseating all the connections in the control panel and that didn't help. It's still off two inches and it still won't let me calibrate it. Any suggestions on what it might be?
    Thanks in advance!
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
  • Hansoon
    • Sep 2007
    • 3389
    Re: Dp C354 Touch Panel Won't Calibrate
    Small change there is debris between the operator side of the display frame and the touch panel but most of the time you have to replace the touch panel itself. The conductive compound used to attach the ribbon cable is disintegrating by time and humidity.
    Hans
    • copiman
      • Sep 2011
      • 861
      I would have to agree with Hansoon. I checked the bulletins, but did not see any for touch screen. There are upgrades for the screen on some Panasonics but not the color ones. If it were me, I would disassemble it and clean everything with a slightly damp cloth of alcohol. Let us know what you find.
      • doug94550
        • Dec 2011
        • 138
        Gotta' go with Hansoon.
        Swap out the touch screen.
        • User Name
          Awesome Sauce
          • Nov 2009
          • 405
          Yeah, my gut told me it would be the touch panel. I had one ordered and replaced it yesterday and it worked fine.
          Thanks for the help everyone!
          O.o
