Panasonic dp1510p damn problem
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Electrical] Panasonic dp1510p damn problem
    hi to all
    i have problem with panasonic dp1510p , displaying E04-02 ,
    --- i've checked and replace new thermistor but no result
    -----i've replace new thermal fuse but No result
    -------i've replace exite and external sensors but no result
    NB/ But when i replace new DC controller , machine work well !!
    so please tech me what is the problem exactly in the DC pcb !
    how can i resolve it!
    thank you in advance.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • copiman
    • Sep 2011
    • 861
    Re: Panasonic dp1510p damn problem
    E4-02 is a paper jam in the fuser. The machine is detecting a jam. Could be sensor, broken actuator, connection issue, or LPC3 board. Usually for me its a broken exit sensor actuator. Why it worked when you replaced the DC controller, I'm not sure. Maybe the 5v for the sensor was missing. Also, I'm not 100% sure but when you get fuser codes, they are reset by going into service mode F9-06>04 (LBP Fuser Reset). Again, not sure on this jam code, but its worth a shot. Maybe when you swapped the board it reset itself. Try putting the original board back on and see if it comes back? Hope this helps.
    • jaybug
      • 25
      Don't you have to do a LBP fuser reset for a E4-02 also after you remove the jam.
      • sweet.persona
        Engineer
        • Nov 2009
        • 414
        thanks for replys
        i tryed to do (LBP fuser reset) many times but No result , i remove the DC controller and i've placed it in another machine , but the E04 still appear in another machine!!!! the problem exactly it is on the Dc controller ! really i did not found solution to resolve it
        please there is another idea:!!!
        DAMENE ABDEL AZIZ
        DJELFA
        • ZOOTECH
          Senior member of CRS
          • 3375
          Originally posted by sweet.persona
          thanks for replys
          Look for a cold solder joint on one of your connector pins.
