Panasonic DP-C262 PCL6
  • smithbro
    • Jun 2025
    I have the error code E02-02. Diagnosed it and found the little plastic "gear" broken under the no.2 tray. Is there any way I can get a part number for this device? And where can I order one? Thanks.
  • tnrtt
    • 156
    Re: Panasonic DP-C262 PCL6
    Is it the coupling on the lift motor, or on the tray itself?
    • smithbro
      The white plastic coupling (if that whats you call it?). It fits over a spindle and spring and receives the rod from the tray.
      Thanks.
      • mojorolla
        The Wolf
        • 2594
        FFPHQ0063
        • smithbro
          FFPHQ0063
          [ATTACH=CONFIG]22611[/ATTACH]
          That's it!!! Thanks! I assume 4029 is the part number. Would I be able to order this, or do I have to go through Panasonic or a repair service?
          • copiman
            • Sep 2011
            • 861
            Look above the picture mojorolla posted. The part number is FFPHQ0063. Not sure if you can order directly from Panasonic. I'm sure a local dealer would sell you one. If not Precision Roller has it in stock for $9.95.
            • onetek
              • 318
              If that breaks, you have a good chance that the plastic splined shaft it slides on is also damaged (twisted).
              • smithbro
                Thanks all!!!! I'll take it from here and let you know how things turn out........
                • smithbro
                  Got a friend who works on these things..... I'll have him come by. Thanks again.
