panasonic DP 4530 Image shifts intermitently(lead to trail) .2-1 inch
  • Discountcopiers
    • Jun 2011
    • 52
    [CQ] panasonic DP 4530 Image shifts intermitently(lead to trail) .2-1 inch
    I have a subcontractor that is having a problem with image shifting .
    Here are the syptoms.Shifts on all trays ,on the glass,document feeder and print mode.
    it definetly is a processor problem.
    opened up feed and transport areas cleaned rollers nothing obvious ...
    I couldnt find a buckle adjustment for theis model??My guess would be a registration clutch.
    does anyone agree and have the part number .Or is there another check. thanx arnie
  • onetek
    • 318
    Re: panasonic DP 4530 Image shifts intermitently(lead to trail) .2-1 inch
    I would go for rego clutch. (buckle is called paper loop in F6 mode)
    • User Name
      Awesome Sauce
      • Nov 2009
      • 405
      I would have to agree with you. Based off of your description I would say it's the registration clutch. I don't know the part # from memory.
      Just because you're not paranoid doesn't mean they're not out to get you.
      O.o
      WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
      • Mad_Coachman
        • 99
        L9EAAK000008 - REG CLUTCH
