DCP 323 Display adjustment
  • yormets
    • May 2009
    • 336
    Where in the world in the 910 page service manual is the adjustment for the touch screen? I've been searching for 15 minutes. The touch is off. Needs to be honed in.
  • yakyitz
    • 243
    Re: DCP 323 Display adjustment
    Power off both switches. power on SIDE switch. power on main/back switch while holding down "FUNCTION" and "ENERGY SAVE" buttons. After a couple of seconds screen will come up with crosshairs.
    • yormets
      • May 2009
      • 336
      Thank you very much. I will be out there today to adjust it.
      • yormets
        • May 2009
        • 336
        That procedure takes two people. The energy key and function key are on opposite sides of the keyboard taking two hands. There is no way to hold down the keys and reach the back on/off switch. I had someone help me, however it still did not go into any screen adjustment mode. Are you sure that the procedure is for this model? Where would it be in the service manual? I have that.
        • User Name
          Awesome Sauce
          • Nov 2009
          • 405
          The procedure is listed somewhere towards the front of the manual. I forget which page without looking in the manual. You can do the calibration by yourself. The way I do it is I turn off both switches, turn on the side switch first, then the back switch, and then you have to be quick and press the FUNCTION and energy saver buttons before the machine has a chance to start up. Just keep holding down those two buttons until the + symbol appears on the top left-hand side of the screen. I've also found that if you're too late with the buttons and you press and continue to hold the buttons the machine will stay locked up and not start up until you release the buttons, then it will continue to start up normally and you have to try again.
          Just because you're not paranoid doesn't mean they're not out to get you.
          O.o
          WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
          • User Name
            Awesome Sauce
            • Nov 2009
            • 405
            Edit Again: I'm just getting rid of all my incorrect information. I was confusing the service mode keys and the touch panel calibration keys. Sorry.
            O.o
            • yormets
              • May 2009
              • 336
              Now were talking! Is it the same procedure? With the both the switches? You can't reach the back switch and hold any keys.
              • yakyitz
                • 243
                I Don't want to disagree, but, here goes. There definitely is a function button on the right and the energy save on the left and "user name" is right as to how to go about it. Turn off both switches, turn on the side switch first, then the back switch, and then you have to be quick and press the function and energy save buttons before the machine has a chance to start up. Just keep holding down those two buttons until the + symbol appears on the top left-hand side of the screen.
                • User Name
                  Awesome Sauce
                  • Nov 2009
                  • 405
                  I apologize. I'm confusing the service mode procedure with the touch panel calibration. My bad.
                  its the original size/ledger key that's not on the color models and thats why the copy key is used for entering the service mode.
                  O.o
                  • User Name
                    Awesome Sauce
                    • Nov 2009
                    • 405
                    Page 186! COPY and energy save keys! I was right!
                    You had me questioning reality yesterday. I was pretty sure that's how it was done but it's been awhile since I've done the screen calibration on one of those so I just figured I was wrong but I had to check just to be sure.
                    O.o
                    • yormets
                      • May 2009
                      • 336
                      I'm going back out today armed with all this good information. I found it in the manual (with your help). Thanks to all for all your input.
                      • yakyitz
                        • 243
                        "User Name" I stand corrected. (I shouldn't have been so pig-headed. I haven't done it in a while either)
                        • User Name
                          Awesome Sauce
                          • Nov 2009
                          • 405
                          No worries. I didn't mean didn't mean for my response to seem rude or so "in your face" if you know what I mean. I was just really happy that I'm not going senile. Lol
                          O.o
