DP262 rolled over black counter
  • panashiba
    • Jan 2007
    • 37
    Has anyone had any issues with these counters rolling over after 5 digits? I have a machine that has been in the field since February 2007. Since then, all meters on both b/w and color have gone in order up until this month. Last month my b/w meter was 95k and my color was 44k. This month my b/w meter is now 12k and my color is 52k. I called tech support which got me no help and no information. Has anyone seen this? I can't imagine the counters only go 5 digits and won't roll to 6. The other wierd thing about it is that based on their avg monthly volume, they would be right about 102k on b/w which looks like I am just missing a digit. Unfortunately, I don't have very many of these and this is the only one with this many copies on it.
  • yakyitz
    • 245
    We have a number of these over 100k, never had such a problem. Can you manually enter a 6 digit number and after pwr off/on does it keep it?
    • panashiba
      • Jan 2007
      • 37
      We were able to change the counter in F7 mode for the b/w count and it saves after power cycle. However, the new count will not show under counter view. Firmware is current and Panasonic tech support had no answers or suggestions. So, I am not sure what is going on or how to fix it.
      • yakyitz
        • 245
        First of all I'd like to know if you spoke to Tony at tech support, he is tops and never let me down. Now back to the problem was a shipment set performed upon initial setup of the machine? If not that would be the first thing to do. then I would reinstall the firmware if that fails it's gotta be a board problem. (I don't envy you) good luck.
