Panafax UF 8200
  • gbfan
    • Aug 2010
    • 19
    [Dead] Panafax UF 8200
    We are a Sharp dealer that have a few Panafax machines out in the field. I have one that flashes the energy save light and will not power up. The last time this happened to this machine we replaced the main board in it. The manual states that you can try flashing it first. It seams to be a cheaper alternative. The customer is not on contract, so i would like to keep cost down. The problem is we can not find the firmware online to flash it. Where can we get the firmware to try the update first?
    thanks in advance
    Matt
  • mojorolla
    The Wolf
    • 2609
    Re: Panafax UF 8200
    PSCNA
    You will need a login though....
    • Luther
      • May 2006
      • 682
      Re: Panafax UF 8200
      try here:Download - LICENSE AGREEMENT | Business Fax | Office Products | Business & Professional | Support | Panasonic Global
      • gbfan
        • Aug 2010
        • 19
        Re: Panafax UF 8200
        I believe this is the stuff you need if you want to use it as a printer. I need the firmware.
        • gbfan
          • Aug 2010
          • 19
          Re: Panafax UF 8200
          PSCNA
          This looks like where I need to go. I will see if anyone here has a user login, but I do not think so. We only have a few of these out in the field so I unfortunately don't think we are an authorized dealer.
          thanks for the quick reply
