DP 2330 memory question
  • canjbi
    • Oct 2012
    • 11
    Would someone be so kind if they know to provide some spec info for the memory for the DP-2330.
    I know compatible memory is available, so I just need to know what kind.
    I would like to add a 128Mb SODIMM and a flash card.
    I have a generic 8Mb Fast Flash Card already but if i plug it in the machine locks up, so can it be formatted to work?
    I have a box full of SODIMM ram so I am hoping one of them will work, otherwise I will source based on spec.
    Thank you in advance to anyone who can help out.
  • mojorolla
    The Wolf
    • 2583
    Re: DP 2330 memory question
    I believe 64mb is the max on that model.
    The flash is used for fax; if it has no fax kit, it will lock up.
    • canjbi
      • Oct 2012
      • 11
      Thanks for the help.
      The machine takes up to 128mb
      what i actually want to know is:
      1. What kind of ram. Speed/frequency/buffered or not
      2. Does the flash card need any kind of special programming?
      i have an 8mb generic flash card and the machine locks up with it in
      the machine does have the fax kit as I just installed and configured the fax.
      Any ideas?
