Printing problem.
  • masyuk
    • Nov 2014
    • 15
    Printing problem.
    Hi guys. Anyone have facing this problem before? When I print from pc and smc report, this line appear.
    Sent from my GT-I9205 using Tapatalk
    • 37489
    Re: Printing problem.
    1. Always include the model of the machine you are having problems. It was a pain having to try to read it on the Windows printer test page.
    2. Does it also happen when copying?
    • masyuk
      • Nov 2014
      • 15
      Mpc3000.
      • masyuk
        • Nov 2014
        • 15
        Copying also same problem
        • NeoMatrix
          Senior Tech.
          • 3513
          Looks like the machine has been left in SP/Service mode "line test"???
          • masyuk
            • Nov 2014
            • 15
            Nope.. test patern also problem.
            • allan
              RTFM!!
              • 5462
              How many pixels or dots in the width of the line?
              Whatever
              • masyuk
                • Nov 2014
                • 15
                Huh[emoji15] need to count?
                • allan
                  RTFM!!
                  • 5462
                  Just looking for clues.
                  Whatever
                  • mikadonovan
                    • May 2008
                    • 2931
                    Maybe someone is messing with you. Could be lined paper loaded in the tray
                    NEVER ASSUME ANYTHING
                      • 37489
                      What have you tried so far?
                      It looks to me like the lines do not go all the way to the edges. Therefore we can rule out anything mechanical like drum, ITB or fusing unit. The most likely problem would be the image processing on the BICU. It could also be the memory DIMM(s) on the controller.
                      • allan
                        RTFM!!
                        • 5462
                        Hehe i have had that before.
                        Whatever
                        • Polarbear
                          • Feb 2012
                          • 1070
                          I would look at memory or the IPU first. If all else fails i would check the laser, but looking at those prints, the image is getting corrupted before printing which is why is say memory or IPU.
                          Press the GREEN button!!
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            Change the paper down/up to A5 /A3 and see if the line spacing changes linear to paper sizing.
                            • Zeldaman
                              • Mar 2011
                              • 946
