SC 623 on MP 6500
  • mtebka
    • Dec 2013
    • 38
    [Error Code] SC 623 on MP 6500
    Can anyone tell me how to resolve error SC 623 on MP 6500. this error has been coming up intermittently. Thank you for the help.
  • rosspt
    • Mar 2012
    • 92
    Re: SC 623 on MP 6500
    It means one of your trays (1-3) is not connected. Check your harnesses for all feed units to make sure they are solid. Follow the connections between your BICU board and the IOB. Make sure that the are all connected properly and no damage (ie pinched) to the harnesses. If nothing is found I would first try replacing the BICU. If it is not the BICU, put the original back and try the IOB. This SC code is covered lots in the Goose Guide for multiple machines.
    • bob marley
      • Jan 2012
      • 1339
      Live for yourself and you will live in vain. Live for others, and you will live again
      • mtebka
        • Dec 2013
        • 38
        thank you guys. I will go and check today.
        • mtebka
          • Dec 2013
          • 38
          Went back to the client and checked the harnesses for tray 1 to 3. They are all ok. The error came up again after I had switched the machine on. the machine was indicating a paper jam at A and there it displayed J003. Any more ideas?
          • kannuki2
            • Feb 2012
            • 398
            Disconnect the connections from paper feed unit 2 and 3. see if it resets
            • mtebka
              • Dec 2013
              • 38
              I did that and it didn't work. Thanks for your suggestion
                • 37062
                From Goose's Guide:
                SC 623 BICU tray 1-4 communication error, replace IOB
                SC 623 BICU tray 1-4 communication error, check harness and connections
                SC 623 BICU tray 1-4 communication error, BICU defective
                I have had broken leads in wiring harnesses.
