mpc2500 yellow pcu not working
  • ponto700
    • 144
    Hi,
    I have one mpc2500 that when i print the test pattern the yellow dont apears... we change already the pcu and the transfer unit and still doing the same but the pcu on other machine works. there is no sc code on loggin data and machines dont give any information.
    did someone already have this problem before?
    thanks in advance
  • skynetto
    • Sep 2012
    • 257
    Re: mpc2500 yellow pcu not working
    Check broken wire on ITB.
    • petermuylle
      • Jul 2015
      • 18
      Agreed, happend to me once, the charge cable for the Yellow transfer roller was broken.
      Might also be the contact springs to the itb that are bent/broken.
      Also check the conections on the high voltage board.
      • Zaxxon
        • 608
        My vote is on the ITB unit too.
        Please start you post with brand, model, problem.
        • Debs1964
          • Oct 2010
          • 1693
          Mine too
          There are 10 types of people in this world, those who understand binary maths and those who don't
          • bob marley
            • Jan 2012
            • 1339
            agree with u
            Live for yourself and you will live in vain. Live for others, and you will live again
            • andy227
              • Jan 2013
              • 219
              Doesn't he already say "changed transfer unit" though ?
              • francisco
                • Nov 2009
                • 168
                Originally posted by ponto700
                Hi,
                thanks in advance
                drive gear maybe is broken (there are four, one for eathc color) it happens to me once
                and theres no part number you have to change all drive unit
                • Zaxxon
                  • 608
                  Finally one awake tech
                  • Zeldaman
                    • Mar 2011
                    • 946
                    Hi there!
                    I agree with francisco, when itb-unit is changed then the drive-unit is gone. Had this 2 month ago on the same model, the salesman changed it in a 20er Metis.
                    Greetings...
                    • ponto700
                      • 144
                      Hi to all,
                      is this the drive unit mentioned by Francisco?
                      is yes so i will remove from other machine and test and then i will post the result.
                      thanks.
                      • Brianneoe
                        • May 2015
                        • 322
                        check the shutter for the laser unit, the one for the yellow might be stuck close
                        • skynetto
                          • Sep 2012
                          • 257
                          The shutter is a metal plate wich covers all the lasers at once. If one is stuck all are stuck.
                          • L-IQ-uid toner
                            • Mar 2014
                            • 17
                            From Goose Guide:
                            single color missing - no image on drum, no codes then replace NVRAM
                            single color missing - if image on drum, transfer roller/bias issue
                            single color missing - F/C mode only, single color is OK - reformat HDD
                            single color missing - bad memory chip on toner bottle
                            single color missing - set SP 2-914 laser shutter open and close should be 38
                            broken transfer roller connector in ITB unit
                            • Brianneoe
                              • May 2015
                              • 322
                              i also had a tech who uses a larger "c" clip to fasten the brass bushing for the developer unit. The clip came off and grounded between the bias terminal and frame.
