MP C4000/C5000 fusing unit setting error
+ More Options
Posts
  • LNorris
    • Sep 2008
    • 645
    i have this message pop up every now and then. I have moved the fuser from a C4000 to a C5000, message follows. I have reseated fuser. it clears and then it appears if the right door is opened or after coming out of energy saver. if I open the right door after the error and close it, message goes away and runs for a bit.
    any ideas to look for? I'm not sure (still looking) at what the machine is looking at for the not set correctly. goose's guide showed nothing.
  • Zaxxon
    • 608
    Re: MP C4000/C5000 fusing unit setting error
    Fusing connection in the machine is broken, part to be found in point to point diagram.
    Please start you post with brand, model, problem.
