Ricoh DF75 1022/1027 jams
  • Andy
    Feeder jams almost every time at registration switch. Anyone have any experience with this? Do the switches ever go bad? Is there a quick fix? Anyone have a part number? TIA
  • Clif
    • Jan 2007
    • 49
    The sensor or actuator may be dirty, dislodged or broken. The photosensor doesn't usually fail.
    • nmfaxman
      • 1702
      Found some main boards bad due to not reading proper paper size from the width sensors.
      • TonerMunkeh
        Professional Moron
        • 3865
        Most likely the registration sensor is just dirty. When you remove the part that covers the sensor with the metal arms either side, the reg sensor looks into a hole on this part. Make sure there is no paper dust or tippex in there.
        Hit it.
        • neilt69
          TEAM WORKS
          • 17
          clutch and reflective sensors can be cleaned can be checked by input/output sp modes and free run check on peripheral sp, all the suggestions i read were right.
