mp 4002
  • T911
    • Jun 2007
    • 628
    mp 4002
    anyone have the firmware they can share to fix the fax not coming out of sleep mode. if the machine is awake the fax works fine. once the machine goes to sleep the fax will not receive any data. thanks
    • 37495
    Re: mp 4002
    Not a firmware problem. At least not mentioned anywhere in the current firmware history. Check the settings in User Tools.
    • Getoner
      • Jul 2015
      • 8
      Re: mp 4002
      Ricoh TSB 001 seems to cover this problem.
      rfg051730.pdf
      • skynetto
        • Sep 2012
        • 257
        Re: mp 4002
        Fax anc FCU firmware are at version 9 at the moment. Are you sure you have't update them cause the problem has been resolved since version 2.
        • T911
          • Jun 2007
          • 628
          Re: mp 4002
          i haven't updated the firmware, i do not have access to it. can anyone provide the latest version with any important notes to be aware of to resolve this issue that my customer is having right now. thanks much
