Ricoh MP171SPF Firmware
  • Chillaholic
    • Oct 2010
    • 40
    Hi techs,
    I have a MP171SPF with adress book error and no access to newer firmware.
    I can change the controller board, but without firmware update it would be toasted soon too.
    In exchange I could get you some Konica Minolta stuff if you need.
    Also I have a problem that i dont own a small 512MB or 1GB SD Card, is it possible to flash the MP171 by its web interface?
  • Gift
    • Mar 2011
    • 2459
    Re: Ricoh MP171SPF Firmware
    Nothing is toasted - quick and dirty solution is do some partially memory clear:
    SP5801-015 (Initializes the UCS (User Information Control Service) settings)
    SP5846-050 (initialize all adress book)
    System/Copy FW 1.04 or newer does include all fixes regarding SC870/adress book errors - still these do occure from time to time^^
    • Chillaholic
      • Oct 2010
      • 40
      Not sure which firmware is installed on that machine, thats my problem, hope it includes at least 1.04.
      Thanks for your answer, but I found this solution before.
      Just wanted to be sure I dont see this problem soon again.
      Last week they could solve the problem themself by just restarting the machine.
        • 37491
        You can use WIM to update the firmware. You to download the Remote firmware. You can also use a utility such as MiniTool Partition Wizard to partition a larger SD card the 1GB.
        MiniTool Partition Wizard, the excellent magic for Windows.
        • Chillaholic
          • Oct 2010
          • 40
          Thanks for the answer, so I wont need to buy an old SD card from ebay.
          I fixed the problem with SP-5846-50 and SP-5801-15, phone book is working at the moment.
          But I also found out the machine has fw 1.01 and I still need a newer firmware asap (1.07 would be up to date I think), before the error comes back again.
          • Klydon
            • Mar 2009
            • 243
            Good info on the partition tool. Thanks.
            • StephenB
              • Aug 2015
              • 243
              Just get an old SD card from a junked ricoh and format it to use for firmware updates.
              I keep seberal around, reformat (to erase) and load different FW for different models.
