Ricoh MP C2500 Dark Display
  • printlessguy
    • Sep 2015
    • 63
    Hello all. and thanks for the help
    I have a Ricoh Aficio MP C2500 that prints and copies fine. cant scan because I cant read the display. if you shine a flashlight on the screen sideways you can see the information but not enough to do much. do you think it is the LCD B2231498 or the invertor board B223 1486 or something else.
    thanks again
    Andy
    is it worth putting one in it too
    • 37491
    Re: Ricoh MP C2500 Dark Display
    You cab try seeing if you can connect your meter in such a way as to read the output from the invertor. Be careful, it is over 100V AC. If you have voltage it is the back light on the LCD.
    • Polarbear
      • Feb 2012
      • 1070
      thanks again
      Andy
      The backlight on this works the same as a laptop lcd. It has a tube light with inverter board. Although fairly robust they do fail, and replacing the lamp normally cures it.
      Press the GREEN button!!
      • printlessguy
        • Sep 2015
        • 63
        Hey Polarbear any hints on where to get one? I dont see the part number in the parts manual. so I am guessing its a non standard repair
          • 37491
          You will most likely have to identify the maker of the LSD panel. Might be a manufacturer's label on the panel with their model number on it. On some the back light is not removable with out destroying the panel.
          • Iowatech
            Not a service manager
            • 3930
            Someone started a thread where they were looking for the same thing, and someone else gave a source on where to get the back light bulbs to LCD panels. That was a long time ago though.
            I think if you search here for "LCD panel back light bulb" you'll come across that thread.
            Hopefully the place is still open.
            Last edited by Iowatech; 09-10-2015, 03:41 AM. Reason: Had to remove some confusion and stupidity
            • Polarbear
              • Feb 2012
              • 1070
              The inverter has a part number: B223 1486 Invertor - TFT
              The panel is in all probability made by Sharp as are most lcd panels in these machines. There should be a label on it somewhere.
              If all else fails replace the lcd (without the touch panel glass) as it is 2 separate pieces.
              • printlessguy
                • Sep 2015
                • 63
                thanks for all the information everyone. the user is going to think about the repair. another question would be can this still be used as a scanner but from the PC pulling the scan verses the machine sending it to the pc thanks again
                  • 37491
                  As long as the only problem is the display, yes. Just install the TWAIN drivers on the PC.
                  • printlessguy
                    • Sep 2015
                    • 63
                    thanks I thought so but wasn't sure. is there a preferred software or just use adobe ?
                    • blazebusiness
                      SanDiegoCopierRepair.com
                      • 1250
                      Almost any Twain compliant program will do.
                      • qbert69
                        • Mar 2013
                        • 1152
                        The Proper Term for the Backlight is "CCFL"...here are the search results for CTN!:
                        REACH FOR THE STARS!!!
                        Konica Minolta Planetariums!
                        • Sashko
                          • Oct 2009
                          • 110
                          Check the fuse (+24V) on LCD board.
