MPC3002 and series--- fuser question
  • tonerhead
    • Sep 2009
    • 582
    We are getting bent over and bored out every time we need to replace the fuser belt assembly. Apparently you can not get the (belt) sleeve by itself from Ricoh. Has anyone found a source for these only? It is such a ripoff to have to order the assembly.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
  • Zaxxon
    • 608
    Re: MPC3002 and series--- fuser question
    It is the part behind that lubricat the belt need to be replaced too, thats why changes assembly we change.
    Please start you post with brand, model, problem.
      • 37517
      Thew belt itself is easily damaged.
      • Polarbear
        • Feb 2012
        • 1070
        There are companies that supply the sleeve only, with lubricating grease. It is much more cost effective than replacing the whole unit.
        We have come across a company who imports these sleeves, so i am sure you should be able to find the same, as in all probability it is coming from China.
        I am sure a quick search on Alibaba.com will yield at least one supplier. Also a lot of compatible parts are coming out of India lately and the quality is not bad.
        See attached screenshot.
        Press the GREEN button!!
        • volla
          • May 2015
          • 2
          Do you know where one can find the material behind the sleeve? If that unit is damage an new sleeve will not last.
