MPC3502 Bent K Toner Pin -SC681-16*
  • copier tech
    • 8144
    [Error Code] MPC3502 Bent K Toner Pin -SC681-16*
    Hi all, I went to a 3502 today that has the message that theK toner is not fitted, I can see that the pin inthe rear of the machine that makes contact with the chip on the K toner isbent.
    L
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: MPC3502 Bent K Toner Pin -SC681-16*
    Yup happens from time to time if the customer rams the toner bottle in too hard.
    Easy fix though, swing the controller cage out and there it is secured with 5 or 6 screws and a single connector.
    D1445119 PCB: BRB
    • copier tech
      • 8144
      Great, thanks for your help, it sounds a lot easier to fit than the 305!
      • Zaxxon
        • 608
        5 minutes fix, no sweat
        Please start you post with brand, model, problem.
