Ricoh MPC 4000 ADF J054 Error
  • Doug James
    • Jan 2012
    • 935
    [Jamming] Ricoh MPC 4000 ADF J054 Error
    I put new PU sep and feed tires in this and out of the blue it starts showing J054 jams. The paper makes it's way half way past the slit glass and then jams... I went through and cleaned all the sensors and reseated the connectors on the board. The customer wasn't complaining about this before I worked on it. Had to be "tech lightning" but what. Any feedback would surely help... Thanks so much
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: Ricoh MPC 4000 ADF J054 Error
    Without seeing the doc feeder I'm not sure on this but does this doc feed have the black felt that gets covered in paper dust? & ive done this on a mp2000 but fitted the pick up housing on wrong. It all fitted together and fed but kept jamming going into the registration.
    apart from that my mind is screwed for the day and I'm probably spouting bollocks!
    Incontinentia Buttocks
    • Doug James
      • Jan 2012
      • 935
      I appreciate the feedback.. It's a DF 3010 (B802) I am looking at the manual now... It seems that it has to be paper dust on a sensor, trying to find which one... There are a lot of em I am finding...
      • banginbishop
        grumpy old git
        • Oct 2007
        • 894
        Page 9 of the service manual item F belt tension unit I fitted wrong!
        • sandmanmac
          • 3981
          I'm betting that the Bishop is 'bang' ON!
          Blow out the paper dust in these sensor 'wells'. (I'm not sure what they're actually called)
          I've even used a sharpie to colour a couple of them black, because the felt had faded, and caused the same effect as paper dust.
            • 37491
            Original jam code 054 is a trail edge jam at the skew correction sensor. Lift the top cover of the ADF. There are two sensors in the top cover and two wells with felt pads below them. One is the skew correction sensor. I usually blow the dust off both of them felt pads anytime I have jamming on these. I had one customer in a high dust area an hours drive away that I had to show how to clean them otherwise I was out there about every 1 1/2 weeks.
            • Doug James
              • Jan 2012
              • 935
              THANKS SO MUCH !!! This fixed it right up.. !! Really appreciate all the feedback !!!
              • Doug James
                • Jan 2012
                • 935
                [ATTACH=CONFIG]30676[/ATTACH]
                Thanks so much !! Fixed it right up !! Pic was great help !!
                • Doug James
                  • Jan 2012
                  • 935
                  Thanks so much !! Appreciate ya
                  • GreenTech
                    • Oct 2020
                    • 5
                    had the same jamming problem with an MPC4501, checked the felt pads below the sensors and sure are they full of dust, blew the dust off them felt pads and that fixed it.
                    • luca72
                      • Oct 2017
                      • 1779
                      the part has been modified, now the bottom has been cut off the hole, you can also do it on the old piece, by hand
                      "I'll be back"
                      • sandmanmac
                        • 3981
                        Thread is 6 nearly years old, resolved by the poster, and all you've done is repeat what was suggested long ago
