MPC2551 & Win 8.1
  • Leebs14
    • Feb 2014
    • 457
    MPC2551 & Win 8.1
    I'm having fun trying to get SMb scanning set up, authentication errors every time even though I know I'm using the correct user name and password. Windows 7 machine works first time but 8.1 not happening!!
    Any ideas?
  • mikedci
    • Jul 2010
    • 227
    Re: MPC2551 & Win 8.1
    Update network firmware to 10.63 D1055745H.
    Or set up FTP scanning.
    • tufbnme
      • 493
      Ditto the fw update.
      • Leebs14
        • Feb 2014
        • 457
        Cheers I'll do that today
        • Leebs14
          • Feb 2014
          • 457
          I think you are right as o checked the firmware level and it was 10.62 so I tried to update it through the web page but couldn't? I downloaded the 10.63 file which had s MFW extension I think but when I tried to upload it to the machine I got an invalid extension error? I didn't have a SD card with me. Should it have worked using the web page?
          • laitang
            • Nov 2012
            • 627
            It must be: D1055745H.rfu
            • mikedci
              • Jul 2010
              • 227
              +1 for remote firmware
              not even sure what the mfw extension is sd card firmware would be D1055745H.fwu
              • Leebs14
                • Feb 2014
                • 457
                Is a 2Gb SD card too big to use for firmware? I've been told it has to be a lot smaller?
                • mikedci
                  • Jul 2010
                  • 227
                  Newer machines will take the 2G but i think you'll need a 1G or smaller for the MPC2551
                  • Leebs14
                    • Feb 2014
                    • 457
                    Great advice, thank you, found s small SD card and did the firmware today and the scanning worked first time.
                      • 37489
                      I use MiniTool Partition Wizard to change the partition size on SD cards when I need a card that is 2GB or smaller and only have 4GB cards or larger.
                      MiniTool Partition Wizard | Best partition magic alternative for Windows PC and Server
