Ricoh Aficio MPC 4500 SC 290
NEVER ASSUME ANYTHINGComment
Re: Ricoh Aficio MPC 4500 SC 290
Ok ... the 002 check was on 09 set in 38! But continuous error!Comment
Considering all the help you have been given, please be sure and post the solution when you have the problem solved. Have a great day.NEVER ASSUME ANYTHINGComment
Friends, thank you very much for your advice and your help! I will review the shutter motor to see if it is damaged and repair it! Informs to you!Comment
rookiedave
Bernado, use the following troubleshooting guide before ordering additional parts.
check shutter motor operation with SP 2 914 003 and 004 <----------check if the motor is still working
use SP5-803-108 and 109 to check sensors for change of state
check SP 2-914 001 and 002 are set to 38
reseat CN 266 on IOB
if the motor fails, order a new shutter motor and IOB and replace it at the same time.
Friends! What causes the error is a gear to DC Shutter (B223-1213) ... Damaged gear blocks the mechanism shutter. I'll buy a new one to replace it. Thanks to all!Comment
