Gestetner 3222 : How to access service menu?
  • xtraez
    • Jun 2008
    • 42
    Hi,
    How to access the service menu on my Copier Gestetner 3222?
    Please help.
  • Lagonda
    • Aug 2008
    • 1649
    SP access
    Try ClearModes (the yellow button) 1,0,7, and hold Clear/Stop (the red one) until the screen changes.
    • TonerMunkeh
      Professional Moron
      • 3865
      Originally posted by xtraez
      Hi,
      Please help.
      Are you an end user or a technician? If you are an end user, I recommend you DO NOT mess with any settings in SP mode, you can royally roger your copier.
      Hit it.
      • xtraez
        • Jun 2008
        • 42
        1. Thanks Loganda for your reply .
        2. TonerMunkeh......I'm the new technician for the copier services company and also the end user, helping my wife that running fotocopy services. just for gaining the knowledge.
        3. How to clear error " Replace PCU unit". I do change new drum unit, but don't know how to clear the error.
        Please help me.
        • TonerMunkeh
          Professional Moron
          • 3865
          Please help me.
          Run SP 2801, developer initialisation.
          Hit it.
          • FMC
            • Aug 2008
            • 88
            Your cruel......
            • TonerMunkeh
              Professional Moron
              • 3865
              I know, I'll burn in hell. Just don't want to see a cust completely knacker their machine and then have to pay a fortune to get it repaired, better safe than sorry!
              Oooh crap, just realised what you meant by cruel lol
              Press the YELLOW key
              Type in 1 0 7
              Press and hold the RED key
              When the machine beeps and says "copy SP" press 1
              Then press 2, then #
              Type in 801 then #
              Press confirm / execute / something like that - might ask for a 1 to be put in
              That will get rid of the "replace PCU" message.
              Press exit until you come out of SP modes. Sorted!
              DON'T DO ANYTHING ELSE!!!!!!
              Hit it.
              • FMC
                • Aug 2008
                • 88
                Would be a shame if he knackered his machine rather than pay someone that knows what they are doing.THAT WOULD BE A PITTY.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Can't do right for doing wrong.... hehe
                  Hit it.
                  • b003ace
                    • Jun 2008
                    • 78
                    NEW PCU will automatically clear the message...
                    Please help me.
                    A new PCU will automatically reset the message unless someone fiddled with the drum before intalling it. There is a drive tab on the back of the PCU which contacts a push button in the rear of the cavity. If the message did NOT reset on its own with a new PCU, then you may have reinstalled the old unit, or the unit you received may have not been new. Did you remove the red tapes from the front of the PCU, and the black paper from the drum surface? If you didn't have to do that, then the PCU was definitely NOT new. I always leave the tapes in until after the PCU is in the copier frame to avoid confusing the new and old.
                    • xtraez
                      • Jun 2008
                      • 42
                      Type in 1 0 7
                      Type in 801 then #
                      Ooo... Thanx TonerMunkeh.... thanks for the guidance... but.. there is problem.. i don't find any menu on 801, machine have 802.
                      Please guide me furhter.... thanks.
                      • xtraez
                        • Jun 2008
                        • 42
                        Thanx b003ace.... it happen due to the drive at behind of the PCU is not at the correct position, manually i push it up, and install the drum unit...
                        Tadaaa..... there are no more error...
                        Thanks a lot friends and guru..
                        Thanks a lot.....
                        • johncenna
                          Re: Gestetner 3222 : poor copy
                          any one can tell me ?? i have problem with my machine .. small words cant good copy and if writing is light then nothing will print on the page and page will comes white..
                          plz watch both of them then u will easily know the problem.
                          rply me on this
                          ali.jara14@gmail.com
                            • 37556
                            [ATTACH=CONFIG]25557[/ATTACH][ATTACH=CONFIG]25556[/ATTACH]
                            rply me on this
                            I would advise that you start a new thread instead of hijacking a six year old thread. Be sure to include the model and a description of what you have tried.
                            • ruben
                              The New Guy
                              • Oct 2012
                              • 1203
                              rply me on this
                              Hire a qualified engineer.
