Ricoh 3025e: will a MP2550 toner hopper fit?
  • patterson70
    • May 2010
    • 599
    I have a used MP2550 toner hopper and am hoping it will fit into a Ricoh 3025e that needs a new one. Does anyone know if it would fit? Also, if so, is the toner different enough that I have to empty all the toner out of it? Or can I just pop it in? Thanks.
  • Getoner
    • Jul 2015
    • 8
    Re: Ricoh 3025e: will a MP2550 toner hopper fit?
    I can confirm they take the same toner. Ricoh 2120D
    • sandmanmac
      • 3981
      Can you really? Because, to the best of my knowledge there is no 3025E....so I'm wondering if he's referring to a 2035E ? In which case the answers are "no!" and "no!!"
      Also, if he doesn't have the capacity to identify something as simple as the type of toner for use in a machine, then I'm at a loss
      • patterson70
        • May 2010
        • 599
        My apology, it is a 3025, not an "e", and it does take the 2120d toner. So, can I use the toner hopper? Thanks.
        • copyaction
          • Oct 2007
          • 991
          yes it fits, and also fits savin 8025e
          • rthonpm
            • Aug 2007
            • 2858
            Part of what has made this one of the best lines Ricoh has ever produced is the sheer number of backwards compatible parts. I still have a few 1022 and 2027's floating around in low use situations and I'm comfortable with it from the PM perspective since fuser and dirve parts will be available for quite some time to come thanks to the later models just being changes in covers or speed. I'm NOT comfortable with it from the mechanical perspective since boards and other specific components are getting harder to find, though I have used the fact that later models take the same supplies as an incentive to get a few upgrades to people.
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1257
              That toner hopper unit (part#B027-3501) fits an incredible number of Ricoh models-----------
              •Ricoh Aficio 1022
              •Ricoh Aficio 1027
              •Ricoh Aficio 2022
              •Ricoh Aficio 2022SP
              •Ricoh Aficio 2027
              •Ricoh Aficio 220
              •Ricoh Aficio 270
              •Ricoh Aficio 3025
              •Ricoh Aficio 3025P
              •Ricoh Aficio 3025SP
              •Ricoh Aficio 3025SPF
              •Ricoh Aficio 3025SPI
              •Ricoh Aficio 3030
              •Ricoh Aficio 3030P
              •Ricoh Aficio 3030SP
              •Ricoh Aficio 3030SPF
              •Ricoh Aficio 3030SPI
              •Ricoh Aficio MP 2510
              •Ricoh Aficio MP 2510P
              •Ricoh Aficio MP 2510SP
              •Ricoh Aficio MP 2510SPI
              •Ricoh Aficio MP 3010
              •Ricoh Aficio MP 3010P
              •Ricoh Aficio MP 3010SP
              •Ricoh Aficio MP 3010SPF
              •Ricoh Aficio MP 3010SPFI
              •Ricoh Aficio MP 3010SPI
              •Gestetner 2212
              •Gestetner 2712
              •Gestetner 3222
              •Gestetner 3227
              •Gestetner DSM622
              •Gestetner DSM627
              •Lanier 5222
              •Lanier 5227
              •Lanier 5622
              •Lanier 5627
              •Lanier LD122
              •Lanier LD122SP
              •Lanier LD127
              •Lanier LD230
              •Nashuatec 2705
              •Nashuatec D2205
              •Nashuatec D2705
              •Nashuatec D422
              •Nashuatec D427
              •Savin 2522
              •Savin 2527
              •Savin 4022
              •Savin 4022SP
              •Savin 4027
              •Savin 8025
              •Savin 8025E
              •Savin 8025EP
              •Savin 8025ESP
              •Savin 8025ESPF
              •Savin 8025ESPI
              •Savin 8025P
              •Savin 8030
              •Savin 8030E
              •Savin 8030EP
              •Savin 8030ESP
              •Savin 8030ESPF
              •Savin 8030ESPI
              •Savin 8030P
              •Savin 9922DP
              •Savin 9927DP
              • patterson70
                • May 2010
                • 599
                Installed it today, thank you for the confirmation!
                • patterson70
                  • May 2010
                  • 599
                  And thank you other guys for the additional information.
