Thumb Drive won't work on savin 7502
  • Brian Speerhas
    • Jul 2025
    [Misc] Thumb Drive won't work on savin 7502
    Hello. totally new to this site. Hope this is what I'm supposed to do. I have a Savin 7502 that will only recognize some thumb drives placed into the USB port for scanning. The bad ones work in Toshiba machines but not in the savin. Savin says "device not recognized". Anyone? Anyone?
  • mikadonovan
    • May 2008
    • 2931
    Re: Thumb Drive won't work on savin 7502
    Ricoh specifically states that all flash drives will not be compatible. In the SM.
    NEVER ASSUME ANYTHING
      • 37491
      Compare the size of those that work vs those that do not. Some of the early models had size limitations. Also check the format type (FAT, FAT32, NTFS, etc).
      • Brian Speerhas
        Thanks. Tried that. This is a brand new machine.
        • rthonpm
          • Aug 2007
          • 2854
          Still sounds like a formatting issue. I'd still venture on the flash drives that aren't recognised being formatted as NTFS. Try re-formatting one as ExFAT and see if you get a different result. NTFS support requires a license from Microsoft, which Ricoh probably hasn't paid for, and they try to keep their OS fairly lean so they likely haven't installed one of the open source Unix NTFS readers either.
          • Brian Speerhas
            Thank you!
            • qbert69
              • Mar 2013
              • 1152
              Get this!:
              Fat32Formatter
              Created by a Japanese programmer, it seems to work quite well!
              Fat32Formatter is freeware and made by TOKIWA to format drive larger than 32GB to FAT32, which means it can walk around the OS restriction that you can format drive to FAT32 only the size up to 32GB on Windows2000/XP/Vista/7.
              REACH FOR THE STARS!!!
              Konica Minolta Planetariums!
                • 37491
                Originally posted by qbert69
                Get this!:
                Fat32Formatter
                I haven't try that one yet. I have used MiniTool Partition Wizard. Free for personal use. MiniTool Partition Wizard, the excellent magic for Windows.
