Scan to folder Ricoh
  • PA3040
    • Jun 2014
    • 171
    Dear All,
    Dose any one should have experience scan folder using Ricoh Dsm725 with Windows 8. As per the Ricoh official, it does not support with win8
    Please advice
  • copyaction
    • Oct 2007
    • 991
    Re: Scan to folder Ricoh
    You can use scan to FTP with no problem
    • PA3040
      • Jun 2014
      • 171
      Thanks For the reply
      Using FTP, can we able to send the doc to Folder of the User
      • copyaction
        • Oct 2007
        • 991
        yes you set up a folder in the FTP app you are using and scan right to it.
        • PA3040
          • Jun 2014
          • 171
          Thanks again
          Normally we configure with smb protocol for scan to folder
          • COPIERMAN
            • Jun 2009
            • 559
            if you want to scan smb will need to update firmware on copier
              • 37533
              Dear All,
              Please advice
              Ricoh wants to sell new equipment. If you call them about something that requires a firmware update, they will only check the firmware used in production machines. The B205/B209 products were no longer in production when Windows 8/ Server 2012 were released.
              I do not know if Ricoh in India releases custom firmware up date. If they do, you need Special/Custom firmware for Network Support Version 5.12.5b_LRC4066 with a release date of March 25, 2013.
