sindoh m403 drum reset
  • wilbert.c
    • Apr 2014
    • 24
    [Error Code] sindoh m403 drum reset
    i recently started working on sindoh machines, There is sindoh m403 showing reset drum message and i changed the drum but the message is still on the panel can anyone help me to set drum count ?Thanx for helping
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: sindoh m403 drum reset
    Why did you post this in the Ricoh Forum, instead of the "Other Brands" forum???????????????????????????????????
    Mystic Crystal Revelations
    • sandmanmac
      • 3985
      Ricoh...Sindoh
      Tomato...Tomatto
      (It doesn't really work in text, but you get my drift )
      • wilbert.c
        • Apr 2014
        • 24
        you are right , i posted on wrong forum its because Im used to ricoh machines
        • Baas Sakkie
          • Jun 2015
          • 4
          open front door remove drum re insert drum and hold down the stop button til device shows resetting drum.Should take about 10 seconds power of and on
