Hello
We have a MP 9000, the customer changed location and after everything was done (machine to new location, driver installed and so on), the customer asked to connect the key couter (a simply mechanical pulse counter), that worked for almost 3 years on that machine, i plugged it in at the side of the machine on his connector, but after ONE copie SC 901 (mechanical counter error)...so i tried the whole day to fix the problem, at the end it was a blown BICU Board (maybe the mechanical counter was damaged).....ok....now i swapped the BIcu from a working MP 9000 to this one to be absolutely sure that the problem was the BICU baoard, and the machine starts without problems, so i swapped the bicu again to the other machine, but if i turn on the MP 9000 with defective BICU now SC 601 shows up, and the SP Mode is in Japanese!!, what happend to that machine now??, we ordered a new Bicu today....any ideas??
